The oil filler on my tf is loose due to the bracket coming adrift from the engine block. The bracket isnt broken, the threaded insert in the engine block whick looks like its plastic has pulled out. Its still attached to the bracket by the bolt. Anyone else had this happen? I was thinking of glueing it back with epoxy. The insert looks a bit split but not seen them listed as a replacement.
Sent from my GT-N7100 using Tapatalk 2
