Ah yes, good old Suplex...
Completely clueless!
I has to explain to the Suplex engineer why this was happening to my new damper bottom bushes too.
The problem being that they have used direct copies of the original Monroe dampers...and copied the fault! The internal sleeve in the bush is approx 4 mm too long.
Therefore the bush isn't compressed at all when the damper is bolted on. The bottom fitting can slide about on the rubber bush until it destroys it completely.
Shorten the sleeve by 4 mm and the bush is compressed when you tighten up the bottom fixing. The bottom can't slide about, problem solved.
