11.25752 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
17.224921 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
23.33703 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
29.39829 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
35.584134 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
41.596691 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
47.783781 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
53.902779 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
59.860392 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
65.83191 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
71.771763 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
77.653011 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
83.550432 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
89.430397 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
95.432852 Empty data Fuel system #1 - Closed loop, using oxygen sensor feedback to determine fuel mix.
101.511928 Empty data Fuel system #1 - Open loop due to insufficient engine temperature.
Time(seconds) % Percent
12.322213 0
18.197009 0
24.368902 0
30.403365 0
36.529716 0
42.580352 0
48.728491 -12.5
54.823612 -23.44
60.814495 -30.47
66.796039 -30.47
72.68918 -30.47
78.599188 -30.47
84.522033 -30.47
90.399922 -30.47
96.434531 -30.47
102.545694 0
Sounds like the cat's had it.
Your Fuel system brought up some errors:
Have you filled up at a supermarket recently?
The last time I had a car with total cat failure when shaken it sounded like a tin of marbles give it a shake and see if it rattles
