As I seem to be being ignored on .org I thought I would turn to you guys on here to see if someone can help.
My bud has left me with his TF while he is away and I said I will try and sort out some of the issues with it.
he thought the window mechanism had broken but it hasn't
the window will not drop so I took it all apart and found that
That little bit that stops the window jumping up too far was next to useless,
every time I undid it and put the window back under it when the window came back up it just simply popped over it and I was back at square 1.
so I took it off and put some tape on it to make it thicker, seemed to do the job, put everything back on and tried it and the bugger jumped back over it again, so the window will not drop.
what is this piece called so I can look at getting another one, even if I got another one would it still do the same thing?
the stopper bit is cracked and lost some of its support, I guess hence why its not doing what its meant to do and stopping the window!
cheers
Dan
