Check the petrol cap is on the right way around.
Check the seal on the top of the tank where the fuel pump sits. Passenger side behind your new hoops!.
The cheek of it as if I'd do that lol
Yep, there's an arrow on the black bit:should be at the top. Also check the state of the fuel cap seal.
...or you may have drilled a hole in your fuel tank when fitting your hoops......
(....someone had to say it!)
The tank is plastic so maybe tiny hole or it may be over fuelling and the hoops causes it
