Just suffered a coil failure resulting in a piggy back trip from Marlborough to Southampton, saved on fuel anyway. Coil now replaced and up and running with one proviso one of the tappets is ticking away merrily to itself which in the confines of an MGF is a little annoying.
Car has full service history having had a dealer service 2k miles ago which has documented oil/filter change. and the Head gasket was replaced back in May 2012. Never had a sound before the coil issue and the only negative point to the replacement was a slight backfire on start after the coil was reconnected. I am going to be changing the HT leads as there is a slight flat spot but that is a seperate issue.
I am told the hydraulic tappets can drain but then will refill after a short while but have had the engine running for 20 minutes and its still tapping albeit possibly slightly quieter although that may be wishful thinking.
Any thoughts appreciated.
Thanks to Paul for your thoughts but the oil looks clean.
