Suplex suspension - my experience(it's not good!).
Get B+G to pass your complaint to Suplex directly. I don't doubt that the problem with the canisters is weak springs, I understand that they have experienced problems with stiffer springs fracturing during use.
The bush walking can be solved by reducing the inner sleeve by 4mm.
As to the secondary spring, my opinion is that it is there to keep the slipper joint/knuckle from coming out of the upper arm under full extension.
I wondered about putting them back in.
I hope you get a successful outcome to your problem. If you end up trying the all rear canister set up, I will talk you through my modification, as long as you don't pass it on to Suplex!
Honestly, if I could go back to March, I would go the TF subframe swap route.
- Rich in Vancouver
for slightly less than the cost of the Suplex lumps. That should put off the inevitable for at least a few years.
Replied by PQD44 on topic Re: Suplex suspension - my experience(it's not good!).
Posted 13 years 11 months ago #59570This has now been going on for months without resolution and the way Suplex are treating customers is disgusting. I for one would not even consider using their system if this is the back up you can expect, especially after spending several hundred pounds. :bang:
Replied by Frostie on topic Re: Suplex suspension - my experience(it's not good!).
Posted 13 years 11 months ago #59578Please Log in or Create an account to join the conversation.
I agree with you partial. It's important for the hydragas spring setup only. Under full extension there's no problem with the static total length.David Aiketgate wrote: As to the secondary spring, my opinion is that it is there to keep the slipper joint/knuckle from coming out of the upper arm under full extension.
But with quick movements of the upper arm due to pot holes in the road the diaphragma setup may be to slow to let the alloy cone with diaphragma follw this fast movements.
IMO there's no need to hold down the joints with a coil spring setup cause the spring must be long enough to fill the gap of full extension.
If not, reject the kit.
The front canisters have settled lower with time and use, and I need to adjust them back up to 350mm. If it stops raining any time soon.
- cjmillsnun
Replied by cjmillsnun on topic Suplex suspension - my experience(it's not good!).
Posted 13 years 6 months ago #96252EDIT: or wait for Daryl's kit.
Replied by David Aiketgate on topic Suplex suspension - my experience(it's not good!).
Posted 13 years 5 months ago #101274I have been contacted by Marco from Italy. He purchased a Suplex kit a couple of months ago.
He is suffering from knocking noises from the front units. Now does that sound familiar to you? :pinch:
I have advised him to get back to the company, asap.
Replied by cjj on topic Suplex suspension - my experience(it's not good!).
Posted 13 years 5 months ago #101284Please Log in or Create an account to join the conversation.
Posted 13 years 5 months ago #101285This poor lad only found the forum after he started having the clonking noises and he searched the net. Interestingly, he also purchased from Ecar parts on ebay.
Replied by Davem on topic Suplex suspension - my experience(it's not good!).
Posted 13 years 5 months ago #101287
