Suplex suspension - my experience(it's not good!).
...and the part causing the major difficulties was... THE SPRINGS!
It didn't sound good having to use spacers under the cannisters but it all sounds very dubious now.
The Aus Version, Coil Conversion Kit had loads of adjustment room and the ones who fitted them had theirs high to cope with rough roads. Reading the thread again it also looks like a better engineered solution.
link to GIR's thread
I thought that Suplex had already confirmed that the previous front cannisters were faulty?
"Suplex have tried the returned front canisters and, apparently, they clonk and will only adjust to 350mm. So it wasn't just me then! They are currently stripping them down to find the problem(s)."
You never had knuckle problems with the Hydragas units on the car, the only thing that has changed is the Suplex supplied units? I do not understand the reply sent to you. Why have they not sent you replacement front units?
This has been a disgraceful performance from a specialised supplier of expensive parts the MG community and I am glad that you have brought it to our attention.
:sick: I am however very saddened reading this thread David, this has been a real nightmare, a very long drawn out, nightmare :bang:
In summary I think the attitude of Suplex stinks and the MG community need to know and will, more than likely, vote with their wallets. If Suplex think they can simply ignore customers and try and get away with selling a product, which is basically not fit for purpose, they deserve to have all MGF owners made aware of the problems.
You could always go down the small claims court route, as I believe you do have a strong case and have documented each dealing with them in writing.
I came across this thread on the MGF Register about 'clunking Suplex suspension'.
click here to view
So your experience appears to be the norm with just one or two exceptions.
Replied by alanrt54 on topic Re: Suplex suspension - my experience.
Posted 14 years 1 day ago #58728Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Re: Suplex suspension - my experience.
Posted 14 years 1 day ago #58730Psymon wrote: Any news from suplex yet David?
Not a sausage! They are not responding to my emails.
- Rich in Vancouver
Replied by Rich in Vancouver on topic Re: Suplex suspension - my experience.
Posted 14 years 1 day ago #58740Looks like I had better hang onto them and hunt down a pair of rears as well.
Replied by PQD44 on topic Re: Suplex suspension - my experience.
Posted 14 years 22 hours ago #58746alanrt54 wrote: Lets hope dazlightyear's work better
The amount of R&D David has had to put in to getting the Suplex kit to give anything like a decent ride :bang: , I reckon he's become quite an expert and should look at producing his own kit or helping Daryl with his.
Thank you for posting your experiences.
I to have gone the Suplex route and have experienced similar problems.
Due to the age of my car and the fact I was spending so much on the suspension units I opted to replace all the bushes with Poly bushes, all the knuckle joints and track control joints.
I noticed that on the rear suspension units that if you tried to get the standard ride height the spring rate would get progressively softer the more adjustment I used (very strange), so ultimately I settled for a lower ride height.
First drive, both the front units were so noisy I thought I'd not tightened up the sub-frame bolts (removed for the bush replacement) and of course the car handled like a pig (tracking not yet done). I gradually achieved an even ride height with a slight reduction in noise.
After having the 4-wheel tracking done, the noise disappeared on the right hand side but is still evident on the left. Interestingly the camber on the noisy side is -0'59' (in spec) whilst the quiet side is -1'33' slightly out of spec. Not sure if it's connected though.
I'd be interested to hear how you solved your issues using the rears on the front.
Cheers
- p24hrsmith
http://www.mgocspares.co.uk/acatalog/MGOC_SPARES_SUSPENSION___STEERING_940.html
