My MY2000 is MEMS 2.
I did`nt know about the wedge shape being MEMS3. You learn something new every day
It looks like a MY2000 model looking at the size of the airbox so it could me MEMS2
Well I can confirm the former and was hoping, by this photo, to confirm the latter. Not enough evidence for a diagnosis it seems?
Go with what David said regarding the cheese wedge shaped ECU being MEMS 3 a difference I was not aware of. Failing that take the engine cover off and look on top of the engine for the coil packs
Easy way to check. Look under the car at the exhaust. Between the cat and the main silencer there will be lambda sensor, with wiring attached if it's a mems3 ecu.
I believe my2000 should be mems3 but I don't doubt that MGR would have used up old stock of ecus before changing.....
Why don't you just tell us (me) the VIN ? and the engine number ?
post here to me http://www.mgfcar.de/vin/index.htm
Airbox looks like the latest big one (wide shape with pipe)
Cone shape ECU looks like MEMS3
Oh, if you're going to get technical...
