If your horn works then the problem is most probably due to the connectors under the seats on the seat belt pre-tensioner leads.
IMPORTANT:
You need to disconnect your battery and wait 30 minutes before touching anything - otherwise you risk the seat belt pre-tensioners or airbags going off.
If the horn is not working then it could be a loose connection behind the airbag on the steering wheel.
