I used David and Clives' guides to clean mine last week and it has been noticably better at idle this week.
IACV
- Removal, cleaning and replacing the valve.
IACV
- Replacement guide.
What I also did from 'reading the net' was to reset the ECU (engine control unit).
Resetting the IACV.
Reason for resetting - The throttle has a sensor on it (TPS - throttle position sensor) that sends a 'voltage' corresponding to its position to the MEMS unit (Modular Engine Management system). This tells the computer the current position of the throttle ( ie; How much throttle you are applying) This enables the MEMS unit to calculate the correct operating parameters ( Fuel / Air mix etc).
It is important the MEMS unit knows the absolute min and maximum input voltage it will see on the full extent of throttle to enable it to correctly know the current position it's in. We do this by resetting it.
How to reset the IACV.
If you find that the idle speed is 'hunting' or high, try resetting the throttle position sensor (TPS). Here's how you do this:-
Warm up the engine to its normal operating temperature (the engine requires extra air and fuel when cold). This is actually what the IACV - idle air control valve manages.
Switch the ignition to position 2 so that all the lights dash lights come on but don't start the engine up.
Press the accelerator down slowly to the floor 5 times in 30 seconds.
Wait for 15 seconds.
Turn off the ignition.
The TPS has been re-set and the engine can now be re-started.
You could give this a try before you clean or replace the IACV /Stepper motor. But you should also do it after you have done either of those two jobs as it apparrently allows the ecu (engine control unit) to re-learn.
Feel free to put me right, if I'm incorrect on this procedure. I don't think that it will break your car if you try this. But if it does, the usual disclaimers apply.
