Hello Brian, I used a Rover 75 Turbo engine. The Rod's are 1mm shorter and uses the 160 piston's so compression ratio is lower than a standard NA unit. The head gasket is a MLS with a .5mm shim as well so probably a little lower anyway. It's all bolted together with uprated head bolts and oil rail. I put the VVC inlet manifold onto the turbo engine with all the correct sensors etc to make it run. I used a Kmaps ECU to control it and run 12 PSI of boost.
Space is at a premium but as you can see it is possible and all done with out removing the fuel tank or any cutting of the bulkhead using the OE manifold. There are some more pics on my albums if your interested. I did not document the engine rebuild so the pics could be better but show the set up of the turbo on my return from Monaco. I had to tighten the turbo flange bolts as a slight exhaust blow developed and show the heat shields removed.
Paul.
