Pressurised water systems ony came in the 1950s. We borrowed a TD in SA in 2004 and it hilarios to watch peoples faces as you popped it open to check the water with a warm engine.
Its the famous XPAG in those cars.
Personally I wouldnt "splash out" on these expensive coolants, you are bound to suffer a burst hose before you are ahead on cost. On the plus side if you trust the stuff it does avoid bleeding problems with our cars once you have the system sorted.
