MGTF PolyBush compliance bushes
- Freshmemes
- Apprentice MGer
- Freshmemes
- Apprentice MGer
At least from what I can see from the design of the bush it seems more of an issue of the suspension design. As all of the lateral arms allow rotation in more than one direction, the job of constraining the rear Hub's rotation around that axis is also one by the trailing arm, and as the arm is only fixed at on place this also doesn't fully constrain it. that is in my mind why there is a flat plate on the trailing arm where it sits on the bush to stop it from 'complying' left and right as it were. this naturally over time wears down the rubber it sits on till it reaches the metal.
- Freshmemes
- Apprentice MGer
EDIT: link to suspension diagram https://www.16vminiclub.com/forum/general-public-area/rover-chat/20901-anyone-used-a-mgtf-frame-including-suspension
Could it be that polymer washer that is missing/damaged?
- Freshmemes
- Apprentice MGer
EDIT: found the video here you can clearly see how it wears through
Replied by David Aiketgate on topic MGTF PolyBush compliance bushes
Posted 1 year 9 months ago #208580I would probably use a harder plastic material rather than rubber. As I did when I fixed my compliance bush issue with the F.
2mm thick ABS plastic.
I fitted these over 10 years ago and they are still in A1 condition. They are 60-61mm outside diameter;25mm internal diameter. I used a number of them as shims to take up the worn space on the compliance bush, which is the issue on the F.
I see that the TF polybush kit uses a separate poly doughnut
- Freshmemes
- Apprentice MGer
