Intermittent Starting Issues with My MGF
Intermittent Starting Issues with My MGF was created by rosshaden
Posted 1 year 10 months ago #208119
Hello I am  facing  intermittent starting issues with my MGF. Sometimes the engine cranks but won't start;  and other times it starts without any problems.I have checked the battery and starter motor;  and they seem fine. Could it be an issue with the fuel pump /  ignition system? Has anyone faced  a similar problem;  and what was the solution? Any advice would be greatly appreciated!
Thank you
ross
Source- aws developer associate
Replied by Notanumber on topic Intermittent Starting Issues with My MGF
Posted 1 year 10 months ago #208120
Hi Ross it could be worth using the search feature to check through related threads in first instance as there is some variety in the symptoms and causes of starting difficulties.
It would be worth running a flow test on the fuel pump to rule that out.
Change the fuel filter unless you know it has been changed in the last couple of years as they are often forgotten and they get clogged up over time.
Check for fault codes
Replied by R40MGF on topic Intermittent Starting Issues with My MGF
Posted 1 year 10 months ago #208121
Hi Ross,
As recommended above, I would looking at the fuel system as a good starting point.
Can you here the pump run when you turn the ignition key?
Replied by Airportable on topic Intermittent Starting Issues with My MGF
Posted 1 year 10 months ago #208124
I’m a fan of a fuel system problem & would certainly look there.
Also is your f a “standard” or a VVC car. A VVC car would in all probability have the coil pack bolted to the back of the engine & can be problematic, distributor car can have any number of “standard” distributor problems.
Where are you? If your close enough to me & you want to try a coil pack, I can help.
Posted 1 year 10 months ago #208125
And is yours a Mk1 or a Mk2 F ?
Replied by catherinebennett on topic Intermittent Starting Issues with My MGF
Posted 1 year 4 months ago #211649
=14.0ptThis sounds amazing as I found it very much useful and informative to be honest. Also, I have gone through this post which definitely helped me out a lot as a new member I am looking forward for more such discussions.=14.0pt
Replied by Roverlike on topic Intermittent Starting Issues with My MGF
Posted 1 year 4 months ago #211650
Interesting post ... Hmmm .... Looks like it was copy/paste from somewhere else ... could this be spam I wonder .? ...
Last Edit:1 year 4 months ago by Roverlike
Last edit: 1 year 4 months ago by Roverlike.
Replied by TA22GT on topic Intermittent Starting Issues with My MGF
Posted 1 year 4 months ago #211651
Definitely a Bot..very fake language..
Time to create page: 0.424 seconds
