MG TF 135 starts and runs on 2 cylinders but not 4
Replied by thughes1987 on topic MG TF 135 starts and runs on 2 cylinders but not 4
Posted 1 year 10 months ago #207958
Thank you both for your quick responses. I shall follow your suggestions. A compression tester is on order.
The fuel pump works - I get fuel flowing out of the fuel rail no problem when I disconnect the return pipe from the pressure regulator.
Would you agree that the fact that the engine fires up and runs on 2 cylinders (and on the other 2) indicates that the injectors are delivering fuel and the spark plugs are providing a correctly timed spark? Even if not the precise quantity of fuel and the most perfectly timed spark should the engine not run on 4 cylinders if it runs fine on 2?
Replied by judiths handyman on topic MG TF 135 starts and runs on 2 cylinders but not 4
Posted 1 year 10 months ago #207960
Here is a fundamental question
Is the battery new?
Are you getting full power to each plug ?
Posted 1 year 10 months ago #207961
Thanks for the reply.
The battery is not new and has been discharged a few times but I have been keeping it fully charged since the problem arose.
The sparks appeared strong to me.
Is it possible a discharged battery is the culprit even if it has sufficient power to turn over the engine?
Thanks again
Replied by Notanumber on topic MG TF 135 starts and runs on 2 cylinders but not 4
Posted 1 year 10 months ago #207967
Have you tried leaving the 2 plugs which are under the coils in place and removing the other pair of plugs which have the leads ?
Incidentally do you know how long ago the cambelt was changed ?  It would be worth checking the tensioner and to check the cam and crank timing marks line up as they should in case there may have been some belt slippage.
Last Edit:1 year 10 months ago by Notanumber
Last edit: 1 year 10 months ago by Notanumber.
Posted 1 year 10 months ago #207970
I wouldnt blow the cash on a new one until I had checked the volts on the old one.
I suppose my thoughts are, is it man enough to do all the things necessary on start up?
Replied by Airportable on topic MG TF 135 starts and runs on 2 cylinders but not 4
Posted 1 year 10 months ago #207972
If the battery is man enough to turn the engine over with vigour, there’ll be enough puff to drive the electronics. The output devices which drive the coils should crack the coils, again with sufficient vigour to create a spark man enough to ignite the fuel/air mix.
What you are experiencing is odd.
Have you had all the plugs out & placed them in such a way as they are earthed, you should be able to see how fat the sparks are.
Posted 1 year 10 months ago #207973
Carrying on from that. The system is wasted spark, in other words there are only two pulses instead of the usual four.
I seem to recall (I’m away again so away from my notes!) that 1 & 4 are paired 2 & 3 are also paired.
If 1 is firing so also is 4, but as 4 is at bottom dead centre that spark is wasted.
That probably won’t help sort your problem but it’s interesting.
Replied by Cobber on topic MG TF 135 starts and runs on 2 cylinders but not 4
Posted 1 year 10 months ago #207975
It has been said by some engineers the when a wasted spark system fires at the bottom of the stroke it can help with emissions by igniting any unburned fuel.....as such it is not wasted.... but if your a cynical old bastard like me, you call it a load of bollocks for the engineers to put a positive spin on cost cutting. Less components = less cost.
If they were really concerned about burning any fuel left unburned in the combustion process they would employ a twin spark ignition system which has a doubled up ignition system (2 spark plugs per cyl) this works by igniting the mixture at two places in the combustion chamber simultaneously, this can allow the flame front to travel more quickly thereby burning the air/fuel mixture more completely and producing more power!, this system is seldom used due to cost and added complexity.
Last Edit:1 year 10 months ago by Cobber
Posted 1 year 10 months ago #207976
I can see that working & never considered it. I wander it I can use that as an excuse if I have emissions problems at my next MOT. Probably not.
Posted 1 year 10 months ago #207988
Is there any advance with this problem & if so how was it resolved?
Replied by tnjk on topic MG TF 135 starts and runs on 2 cylinders but not 4
Posted 1 year 10 months ago #207989
Having 2 cilinders open, causes the engine to have less resistance in idling, could be why it is idling with 2 cilinders and not 4. If the car has been standing still for a very long time, the connectors could be corroded.
Firtst my money would be on the electrical system, corrosion due to long storage.
Try cleaning the connectors to the coils with contact spray, and with a small screwdriver scratch the surface to remove any corrosion where possible,
Also the connectors furhter down the line, if there are any, and even remove the large connector from the ECU and clean with contact spray. (remove battery lead first).
Also the ground wires connection to engine and chassis might be subject to corrosion, as wel as the connectors for the plus wires. And the battery could still be the problem, after sitting for a few years it may have lost capacity, or have an internal defect. Also clean the battery + and - poles and clamps, caused a problem with my car after winter storage.
I have also had broken wires on a few old cars, the insulation was flexible original, but turns stiff during the years, which can even lead to wire breach. Nasty fault to find, most probable in the area of the engine that is vibrating and the engine heat causes insultation to harden, a combination causing wire breach in old cars.
The ultimate test would be to check the voltage on the coils when starting and idling on 2 cilinders, but that may be difficult because it has pulses instead of constant power, you need a scope, a garage will have that, and you need to be able to test the wires to the coils while in operations, you so cannot measure at the connector, probably need to remove a small piece wire insulation to connect the measuring probe.
Next would be to check the sensor readings, the ECU uses readings from temperature and MAF, and TDC, and REV to calculate the fuel mixture. You would need an advanced ODBII diagnose reader, to read the values. TDC and REV will probably be ok, MAF and TEMP are sensors that can fail. There are I think 2 TEMP sensors, one for cooling liquid temp and one for air temp.
If the ECU thinks the car is at operating temp, while it is not, or vice versa, it will give a wrong fuel mixture that may cause the engine to stall.
Also here, first check and clean the sensor connectors for corrosion.
If electrical there is no fault, next would be the fuel system. Check the fuel pressure, of course drain the fuel that has been in the car for a few years while in storage, put in new fuel, mount a new fuel filter. Pressure may be ok, but perhaps the fuel flow is not, may be a blockage of some debree somewhere. Although at idling you would not need that much fuel, so I would just leave it at fresh fuel and fresh fuel filter. You could have the injectors tested, but would not be my first solution, but cleaning the electrical connectors on the injectors is a good idea. One step further would be to remove the injectors and clean them with injector cleaner.
And just the same as the coils, a garage can check the injector voltage and pulses.
If the easy approach in the above give no solution, time to check the compression on the cylinders.
If the engine has a compression leak caused by a broken piston ring or a stuck valve, it will not run easily. But given the fact that it will run on cylinder 1/4 and 2/3 I would not suspect this.
Running fine and then stopping suddenly without any signs, indicates something has suddenly broken, perhaps due to the heat.
Having issues in electrical steering pulses to the injectors or coils, may also find its cause in the ECU itself, the electrical components are subject to aging, and don't like heat. The only way to check it to swap the ECU in a garage with another car, but I think the ECU is paired to the key, and perhaps even to the instrument panel, but I am not sure. So not a matter of just swapping I think, you need a garage to perform this test I think.
Good luck in finding a solution
by tnjk
Posted 1 year 10 months ago #207990
Our friend has recommended contact cleaner, which is fine, however do use the proper stuff & NOT WD40!
WD40 is fine for the job it was designed for, which is for expelling moisture, it is not really a lubricant & it certainly is not a contact cleaner.
The chemicals in WD can destroy certain plastics & some electronics are made of those certain plastics. I have seen electronics destroyed by liberal amounts of the stuff.
Don’t let your electronics be amongst those.
Time to create page: 2.392 seconds
