Hi, rear lamps are fine in LED as are the reversing and fogs, I believe the only issue you may encounter is the Indicators are they require the resistance of the lamp (hence the wrong flashing pattern if you lose a lamp) I'm sure some teccy person will come along and correct me or know the correct resistor to fit.
