Just finishing up the little bits and bobs on the TF.
Broken boot lid wiring seems to be a common problem.
This is my take on sorting it out.
Six of the seven wires had broken clean away and the last one was cracked.
It seems to me that the main problem is the way the cable is run through a plastic sleeve that allows very little flexibility. The plastic will bend at its weakest point crushing the cables inside and eventually they will simply break!
I have rerun the harness to the right hand side of the hinge bar and run the cables through woven nylon sleeving, this allows the harness to flex over a much longer area.
I'm going to replace the tywraps with a proper 'P' clip.
The cables are going run to the right of the hinge bar.
Here the cables have been spliced, soldered and shrink sleeves fitted. Don't forget to put the sleeves on before putting the wires together and soldering and the woven sleeving must be slipped on before any of the wires are spliced.
The final result allows the harness to flex over most of its free length.
Geoff.
