Tyres
talkingcars wrote:
Andy the tyre man wrote:
talkingcars wrote:
Andy the tyre man wrote: By law every tyre has to have a date stamp.
Is it not on the inner tyre wall.
When was thst introduced?
By "law" I mean "industry standard " :coat:
When was this introduced?
I do not know when it was introduced but I know why !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! It will not be long before tyres will require changing BY LAW after a certain number of years regardless of condition. We can probably thank the economic crisis of the last few years as to why this has not been brought in via the back door ........................ i.e the EU super state and the Fuehrer ........................ Frau Merkel......................................... through one of her dictats.
iKryten wrote: My f 1.6 02. wanders all over the place like a Whitechapel drunk at 2am when I go over about 65, I have been assured that this is not entirely abnormal and you may wish to increase the load in the front bay just to 'hold her down'. Maybe some extra load across the front axle would improve handling.
Including a front splitter into the equation may also provide more downforce at speed, pull your seat right forward and wear heavy boots.
Sent from my SM-G900F using Tapatalk
The F had a tendency for front end lift at speed. The trophy splitter was introduced to cure this. There are now several aftermarket splitters available which do the same job.
In the TF, the front end was altered to reduce this problem.
If you have a TF or an F with a splitter it should NOT wander at speed, or have a vague steering. If it does then there are mechanical problems with the car.
Another issue with Fs is the problem of rear steer! An unnerving effect where the rear wheels move in relation to the body especially in cornering. This is usually caused by wear in the large bushes on the lower rear arm allowing the hubs to move back or forth. Fitting new bushes or compliance washers cures this issue and makes the car much more stable in cornering. :yesnod:
taken from http://www.mgfcar.de/index.htm
- Smoothyman
- Apprentice MGer
Well I'm happy to report that the car performed faultlessly, no twitching at all, if fact the car was more stable than it's ever been.
Result! I'll order a pair of Toyo's for the front and hope that I get old compound. If not Toyo have said they will replace my rears for new compound free of charge.
My thanks to you all for your advise and guidance in this matter. Cheers everyone.
Rick
- Smoothyman
- Apprentice MGer
I will ofcourse report back after the fitting. Best regards to all and have a good week.
Replied by Plezier on topic Tyres ................... trying new type/make
Posted 8 years 10 months ago #161699Nankang NS-2 Ultra Sport 205/45 R16 87 V
from Pneus Online. Comparing the ratings they are the same as the Falken 914's so it will interesting to see how the drive/grip compared to the Falkens which I have fitted on the 75th Annivesary edition MGF. These NS-2's will on the front hence the slightly narrower 205 width......................... another experiment to see how the narrower width effects the steering and cornering! On the rear will be the 215/40 R16 Runway Enduro 916's that are currently sitting on the rear of the 75th and which will be replaced with another pair of Falken 914's for a matched set.
Someone has to try these different makes/types to find out if they are any good or not for our MG's.
- The driving dutchman
Replied by The driving dutchman on topic Tyres ................... trying new type/make
Posted 8 years 10 months ago #161702Please Log in or Create an account to join the conversation.
Posted 8 years 10 months ago #161703I was doubting between these Hankooks and Toyo's. In the end the Hankooks were cheaper and were said to be better in wet conditions.
Yesterday I read that the new Audi TT is factory fitted with Hankook tyres so the brand is going up! Makes me even more confident in my choice.
Posted 8 years 10 months ago #161704The driving dutchman wrote: They seem not to be of the XL (extra load) type that is commonly recommended, or are they?
Load rating 87 is higher than normal rated tyres and these are going on the front hence the 205 width. The rears are 215's. Just checked the side walls and no XL markings but instead it says "Reinforced" so I think that will do .
Funnily enough many recommend Avon ZV5's and Uniroyal Rainsports which are not XL tyres either. In fact just checking the rainsports are only 83Y hmmm confusing as just checked two vendors and one claims 83Y the other 87Y for the rainsports??????? on load rating and the Avon ZV5 and ZZ3 are both 83W rated.
Normally higher speed rated tyres are also higher load rated.
I'll be interested to hear your opinion on the Nankangs in the wet. They usually don't get a good write up for wet handling performance.
Replied by David Aiketgate on topic Tyres ................... trying new type/make
Posted 8 years 10 months ago #161710Plezier wrote: Someone has to try these different makes/types to find out if they are any good or not for our MGs.
Very true! :yesnod:
That's how I ended up recommending Nexens. :broon:
