NGK Iridium sparkplugs have been ordered online at 1/4 of the shop prize. instead of a whopping €48,50 a piece i've got them for €12,95
Do worn down sparkplugs also count?
I can understand that it runs on idle, and starts protesting when there is a more dense mixture in the cylinder that doesn't want to ignite properly.. the mixture ignites to late and makes the engine run rough.
I think we call this pingelen in Dutch
I get fresh ones tomorrow, an certainly hope the bigend bearings and the rest of the engine have not been damaged..
One of the sparkplugs has an oily residue that might indicate leakage / loosend up
It would have been interesting to know which cylinder which plug was in. I think what we see here is the increased wear caused by 2 of the plugs running with a reversed polarity due to the wasted spark system. Is the old VVC a wasted spark system?
Sorry to bring bad news - could still be the VVC mechs...its always hard to pin point a noise from a video, but from what i can hear i would say based on the heavy knock that is bottom end, but been there before and ended up being VVC mechs, best way to check if its bottom end is to run it and indvidualy remove a plug lead, rev it (yes it will have a misfire) but if the noise goes away on any one cylinder, it's bottom end on that cylinder, either piston, bigend or crank, sounds like bigend to me.
Just realised that you're in Holland,
