Thanks
I've cleaned the jiggle valves, only get flow through the top pipe slowly, but I noticed that although the metal pipe with the bleed valve is hot, the other, thinner metal pipe is not.
Tried squeezing it, and got a bit of air out.
Is this the one which goes to the thermostat, in which case will the stat have jammed (2002/3 car with old system )
I understand they are a pig to get at, after removing the stat am I better replacing the plumbing with the later type ?
Aircon is off an 03 stepspeed, standard Valeo aircon rad, so this should not be the problem.
I've got a pit in the garage, will it be easier from underneath ?
Did your car have the oil cooler, I understand it masks the bolts ?
iirc something covers the access from underneath and you cannot access all items from there. Maybe someone can confirm?
I've no oil cooler, not sure if it masks the bolts completely or just makes access even more difficult. Someone else?
