hi all
just a little point ....i was after the 6 stud flexi to manifold gasket for the TF, yes i know you can still get them, but nobody had one in stock in scunthorpe , so the guy at partco did a bit of cross comparison and found that the vw golf 1.8 gti/passat TD one is the same it is actually 2 mm bigger on the exhaust bore, so will aid in exhaust flow and all studs line up etc and it was only £3.50
if anybody needs a pic as comparison i will post..
Paul D
