Hopefully someone can give me some ideas.
Yesterday I replaced my front and rear discs + pads with EBC turbo groove discs and Green Stuff pads.
I've also replaced the rear calipers as one of them was stuck, and replaced the brake lines with HEL ones whilst upgrading. I've bled the system through on both sides and all seems to be operating ok, however I have a noise, like something rubbing or catching.
The noise does go when braking, and after a journey the back wheels are actually quiet warm. I noticed David Aiketgate article about the handbrake caliper adjustment after I had completed the job. Obviously I had to bleed the caliper, but hadn't pulled the handbrake at all until the footbrake had been pressed.
Been as the rear wheel are warm I think the noise is coming from them, however my jack broken after completing the job last night, so I can't get the wheel off to take a look. I have slackened the handbrake adjuster off in the car in hope it was that, but it doesn't see to have made a difference.
I've notice searching about that the green pads/grooved discs can be noisey but surely not when the brakes aren't on. I've driven about 80 miles now, hoping to bed them in, but the rubbing noise is still there, the brake perform fine though, but I'm just concerned that the discs must be getting hot as the wheels are warm where as the front ones are cold.
I need to get here running for the MG Live event next weekend, so I've ordered a new jack that should be here soon.
Anyone else experienced this ? Any thoughts on what it might be ?
Do I need to get the wheels off and wind the pistons back in on both sides ? ( They were 2 fully re-furbished calipers, so the pistons were both wound back in when fitted)
