Thanks Richard, took the TF back to the garage. Discussed the problem as if I knew what I was talking about The mechanic couldn't see the problem. His reply was "well that's what you get when you buy exhausts that aren't standard Rover parts" I said i wasn't happy so mechanic drilled two elongated holes on the right hand bracket/hook and straightened the exhaust. Noticed this morning that the right hand pipe as you face the rear has melted the plastic above the finisher and the melted plastic has ran like dark chocolate over what was a shinny s/s exhaust pipe. What I fail to understand is the left hand exhaust pipe was in the centre, the right hand exhaust pipe was lifted to the same level and centred as the left, yet the left exhaust pipe and the plastic is ok?
