Cars operate in a wide variety of temperatures, from well below freezing to well over 38C. So whatever fluid is used to cool the engine has to have a very low freezing point, a high boiling point, and it has to have the capacity to hold a lot of heat.
Water is one of the most effective fluids for holding heat, but water freezes at too high a temperature to be used in car engines. The fluid that most cars use is a mixture of water and ethylene glycol (C2H6O2), also known as antifreeze. By adding ethylene glycol to water, the boiling and freezing points are improved significantly.
Fluid - Freezing Point - Boiling Point
Pure Water: 0C - 100C
50/50 mix of C2H6O2/Water: Minus -37C to 106C
70/30 mix of C2H6O2/Water: Minus -55C to 113C
The temperature of the coolant can sometimes reach 121C to 135C. Even with ethylene glycol added, these temperatures would boil the coolant, so something additional must be done to raise its boiling point.
The cooling system uses pressure to further raise the boiling point of the coolant. Just as the boiling temperature of water is higher in a pressure cooker, the boiling temperature of coolant is higher if you pressurize the system. Most cars have a pressure limit of 14 to 15 pounds per square inch (psi), which raises the boiling point another 25C so the coolant can withstand the high temperatures.
Antifreeze also contains additives to resist corrosion.
MOST of the Fs and all of the TFs specify a 50/50 mix of OAT (Organic Acid Technology) coolant and demineralised water. It comes in many colours but generally looks very bright. Common colours are green, orange and blue. Normal water should not be used as it contains minerals etc that can cause deposits in the engine and radiator (just look in your kettle).
Some older Fs recommend you use ethylene glycol, which is the more traditional coolant. Many people have converted to the better OAT coolant, but if you do, make sure that you thoroughly flush the system first as the two coolants do not mix well.
You can get OAT from most automotive car shops. I got mine from Halfords. You can buy 50/50 ready mixed or concentrated and a seperate container of demineralised water.
Leigh, domestic freezers usually run at around minus 18 degrees C ~ put on fast freeze they may go to - 20 deg C
