Invalid or non-existent item ID.Invalid or non-existent item ID.OK quick description of a relay (to continue the thread elsewhere)
It's a switch operated by another circuit.
The idea is you put the inlet (terminal 85) of switching side of the relay (an electromagnet) into the switched live you currently use (the radio circuit if I recall correctly), and the outlet (terminal 86) to earth. You now have created your switch.
Then a wire one side from the battery + terminal, to the relay (terminal 30), the other side of the relay (terminal 87) out to a fuse board (something like this)
Then to your accessory...
A relay looks like this
