  • 2
hard top catches 11 years 10 months ago #54199
Hi
i've just bought a hard top and need to collect it on saturday midday from the cambridge area
just had a look at my car and cant see any catches to fit it.
so my question is will it be ok if i just tie it on to get me home ?
cheers
Paul
Re: hard top catches 11 years 10 months ago #54201
There may be a clue somewhere in this lot Paul. I'm pretty sure someone said you can fit a hardtop whilst the softtop's still on. But, I couldn't say for sure.
SOFT TOP
Soft Top - Adjustment guide.
Soft Top - Cleaning advice.
Soft Top - Rear seal replacement.
Soft Top - Removal guide.
Soft Top - Replacement guide.
Soft Top Sticking - Video solution.
Clearly there's an opportunity for someone to do a 'how to guide' on this subject should they fancy the challenge. ;)
Re: hard top catches 11 years 10 months ago #54202
The catches are on the hard top (as they are on your soft top) they work in the same way,but remember the one behind the seats look for a hook its there!
Re: hard top catches 11 years 10 months ago #54203
the catches should be attached to the hardtop,
I certainly hope so my hardtop has been collected by a friend 3 weeks ago not due back here for another 3.
Re: hard top catches 11 years 10 months ago #54204
Deffo no hooks fitted to the car :( :omg:
Re: hard top catches 11 years 10 months ago #54205
Welcome to the T-Bar Anerley. :)
Re: hard top catches 11 years 10 months ago #54207
Invalid or non-existent item ID.i found a set but cant get them in time :(
Re: hard top catches 11 years 10 months ago #54208
The hardtop fits with the soft top folded down, If your soft top clips on then the hard top will clip on the same place.
There are fittings for the hard top just behind the door. Would you like a picture?
Last edit: Post by Leigh Ping. Reason: Selected as a 'POW' (Pearl of Wisdom) - Added to the guides section. Thanks Stan.
Re: hard top catches 11 years 10 months ago #54210
The hooks are part of the soft top (from memory) your pic is right part but you wont need them in chrome unless you want. the hard top will have a catch at the same near the sun visors and also behind the seats eather side of the engine hatch,near the seatbelt . I didn't notice them til I placed the hard top in place. The catch on the H /top will have a slide mech, just do the front ones first the look behind and all will be reveailed.
The following user(s) said Thank You: Yellow Peril
Re: hard top catches 11 years 10 months ago #54220
a pic in situ would be good thanks
Re: hard top catches 11 years 10 months ago #54222
  • bensewell's Avatar
Is this something I can photo from the MGF? My roof is off so might be able to pic something.
Re: hard top catches 11 years 10 months ago #54223
The main part of the catch is on the hard top. The two metal parts on the car are just close to where the soft top hinges are when it's folded down near the seat belt slot. They are about 2-3 inches long and two 'legs' of hard top rest on these and then the hook just clips underneath...
  • 2
Time to create page: 1.032 seconds
