Mine is a 2008 LE500 so I am assuming similar to a late 2004/2005 TF
The rear fogs aren't working and the switch does not illuminate. The fuse is fine. Front fogs work OK.
Also I have made sure the headlights were on first before testing!
Did later TFs have the rear fogs controlled by the BCU? I don't have a wiring diagram for the later models and wanted some info on how they work before checking it out!
Or could it be a faulty relay to the right of the fuses - not sure which is which though as the handbook does not say!
Does anyone know what each of the relays in the photo are for?
