Another post hijacked..well you can understand it ..there doesn't seem to be a lot of people posting anymore...a lot of common usernames going by the wayside....anyway back to the original post....I've set cb points...not with a rizla paper because I never smoked roll ups ..(well not in the early days)..but I have.opened a bottle of newcastle brown with my teeth,tested a pp3 battery on my tongue...repaired a sinking fishing boat 2 miles out at sea with chewing gum and a beer bottle.. can skin a rabbit...know the meaning of some welsh words like araf,creoso and heddlu started a cold land rover diesel using a newspaper ....sealed thousands of k series engine blocks for mg rover to stop porosity in casting..adjusted drum brakes with the square nut...land rover days...never messed with su carbs. Changed camshafts on ohv engines in situ..replaced oil seals.timed engines..replaced cambelts-k series.fitted sputter bearings,have test run a fly by wire engine using a bike spoke can rebuild most modern truck and bus engines...never done a head gasket on a k series..but when the day comes my sleeves will be rolled up and in I go......had plenty of experience rebuilding turbo chargers.serviced oil slingers. .cleaned crank sludge traps..
..reset main caps...rebuilt oil pumps,air compressors..lapped valves..honed bores.about it really..apart from I can repair a puncture on a push bike.
Latest project full strip down and rebuild..Mercedes v8 twin turbo coach engine...
Never tweeted or used Facebook. .but I know the phonetic alphabet and the blood in my veins often turns into lager.
Im Billy no mates and nobody loves me..
My neighbours have stopped talking to me and I've just hit 50...life is fantastic and I just get on with it...I like talking about cars....sounds more like I'm filling in a dating agency form..dunnit..oh and I keep getting attacked by a jack Russel at work..and my biggest spanner is a 36mm...
