(I had fitted an MGF hood and frame to a TF, which meant much more critical adjustments!)
The chap undone every bolt so it was finger tight.put the window up and the window self adjusted,so bolts done up without opening door by access across the cabin.
Regardless of F or TF, everything is compatible as the tub, doors and roof are the same, regardless of model.
