OEM exhaust tip rust 7 years 9 months ago #169715
Hi Guys,
I know I should be out enjoying my MG
But I don't control the weather...............yet
the exhaust tips look horrible I have tried cleaning them
& I can get them to look better....for a week or so,
but rust doesn't sleep !!
I know the tips are welded on, I know the exhaust is less than 2 years old,
( I didn't purchase it )
what do you guys do ??
I did think paint,
grind all rust away, put on bare metal treatment,
but what paint to use ??
I would like something on the cheap( smoothrite/hamerite )
but do I need a high temperature paint ??
also like the idea of painting inside exhaust like
the Jensen Interceptor ( who remembers those ??)
thanks in advance
Paul1966
OEM exhaust tip rust 7 years 9 months ago #169716
Invalid or non-existent item ID.Invalid or non-existent item ID.The easy option might be one of these Paul. They come in various shapes to fit the TF. :yesnod:
CHROME EXHAUST TAILPIPE TIP TRIM END MUFFLER FINISHER MG MGTF MGF ZR SV
Completed
CHROME EXHAUST TAIL PIPE TRIM TIP MG MGF MGTF TF ZR
Completed
The following user(s) said Thank You: Paul1966
OEM exhaust tip rust 7 years 9 months ago #169720
Thanks for the reply Leigh, I'm not a huge fan of these, I may have to do it :(
OEM exhaust tip rust 7 years 9 months ago #169721
Ok. :)
Have you got any pics of your rust problem Paul?
OEM exhaust tip rust 7 years 9 months ago #169722
Hi Leigh
this is the worst of it,
the other side of this pipe has chrome,
& the other pipe is better,
but still it's ugly :)
I also think the pipes are big enough without a slip over
that may or may not also rust.
Thanks again Paul1966
Last edit: Post by cairnsys.
OEM exhaust tip rust 7 years 9 months ago #169723
The jenson interceptor............what a car
not sure if the jensen was in the protectors in the early 70s
The following user(s) said Thank You: Leigh Ping, Paul1966
Last edit: Post by mgtfbluestreak.
OEM exhaust tip rust 7 years 9 months ago #169724
Oh yeah.........I remember those very well.
When I was 18, I used to drive this one about:
It was one of Dad's collection.
The following user(s) said Thank You: Leigh Ping, mgtfbluestreak, Paul1966
Last edit: Post by Cobber.
OEM exhaust tip rust 7 years 9 months ago #169727
I remember years ago when these were my dream car.....reading about a ff model.....ferguson formula and how the ff was four wheel drive
OEM exhaust tip rust 7 years 9 months ago #169729
Had forgotten about the FF,
I do remember there were 2 engine sizes a 7.4L full fat
& 6.9L economy :omg:
just as the fuel crisis hit !!
& of course the 2 huge fist size exhausts painted red inside !!
Last edit: Post by Paul1966. Reason: red exhausts :)
OEM exhaust tip rust 7 years 9 months ago #169733
The cheap option, if you don't mind abandoning from chrome, is to remove the loose rust with a wire brush and sandpaper, and paint them with hammerite, black,
OEM exhaust tip rust 7 years 9 months ago #169736
If you are prepared to take off the silencer then I suggest you prop up the silencer with the tail pipe soaking in Bilt Hamber's Deox-C rust remover. Once it is shiny clean, sparay with high temperature clear laquer.
willyphixitt
OEM exhaust tip rust 7 years 9 months ago #169743
@ willyphixitt I like your thinking...but I don't think there is enough chrome left to make it worth while !!
@ tnjk YES !! but will the Hammerite (or smoothrite) burn as it is an exhaust pipe ??
Thanks Paul1966
Time to create page: 3.790 seconds
