hi regarding the springs.they are progressive springs that are soft when driving but on braking or cornering get stiffer.they sit in a tube that simply clamps into the hydro pod bracket.so d iy fitting is easy.
What's important when pumping up the hydragas units is to check not only the ride height, but the fluid pressure as well. Really hard, with lots of fluid pressure, and not very high suggests low nitrogen pressure. I would put money on nearly every single hydragas unit having lost significant nitrogen pressure given their age. Dad and a friend of ours have been working on them a bit lately, and every sphere they've opened has been down less to less than 50% of the original pressure, with NOS items that've never been fitted being the worst - some as low as 10%. However, these NOS spheres are the most likely to have good membranes.
It is possible to modify the hydragas units to adjust the nitrogen pressure, basically by sticking a schraeder valve in and pumping them up, in a similar way that you do with the fluid level. The change in the cars which have had this done is impressive, and watching a standard car with proper pressure vs a car with the oz setup round a grass track is quite interesting. The standard car was significantly smoother and quicker. Dad's friend has since modified a number of spheres for a number of people, and all are very happy with them. Only problem for most on here is that he's in Auckland.
To be fair there is little reason that a refilled displacer couldn't last 10 years or more. Most often the nitrogen leaks very slowly over a period of 10-15 years.
Have a look at http://www.aronline.co.uk/blogs/cars/austin/maxi/tech-recharging-maxi-spheres/
I know that it relates to Maxi displacers however the way the system works is the same.
That was very interesting, thanks!
Having read some more again, the rubber membranes dying is not the most quoted reason for failing hydragas units; it's indeed just the nitrogen seeping out and subsequently the liquid replacing the space it occupied.
This would indicate that were there a way to refill the nitrogen in a lot of cases that would rejuvenate the pods. Except that there's no way to do that without some heavy modding it would seem.
In the article above they say that you wouldn't be able to use the exact same placement for mgf and that one would even need to make space for the valves in the bodywork before they would fit back. This alone takes this to a whole another level, as it would mean that even if someone would provide the valve-fitted/refilled units it still wouldn't be just a simple matter of replacing them.
