New MGF Wiper Motor
New MGF Wiper Motor was created by PrivateRyan
Posted 1 year 8 months ago #209492
Hi, everyone.  I have a 1998 MK1 MGF. I am suffering with dreaded wiper motor fatigue. I know and have read all about the removal and replacement of it on here, also the stripping down of the motor to replace the rusty bearing. All very useful and in my case 85% successful. What I am after is a source from the wide world of a replacement aftermarket wiper motor, not £100 plus job, just a good quality motor. I know people have said get a Freelander MK1 motor it is the same but I still haven't got anywhere because I don't have a part number or a model number for the motor. They just ask for a VIN number and then say its not listed against their motor. Apparently there is also some sort of query about the switching arrangement on the motors offered. I just want to be able to reconnect if possible. Please can anyone help me out?? Thanks in anticipation.
Replied by Airportable on topic New MGF Wiper Motor
Posted 1 year 8 months ago #209494
The Freelander motor might look the same in all visible respects but you want a wiper system that functions & not one which blows fuses & makes you, if you are not ordinarily grey, grey.
The problem is in the earthing & that is to do with the switching; our switching is old fashioned mechanical positive pole switching, whereas the Freelander is switched via electronics which is negatively switched.
This crops up every six months or so, I could do with a Freelander motor to see how this problem can be easily circumvented.
Afterthought:
if the motor can be isolated from the car earth? In effect a floating ground, then the motor frame could be either positive or negative ground, depending on which motor is being used.
I’m in my chair in the sitting room with the dog on my knee, the fire roaring up the chimney & thinking it through, if anyone can see holes in my thought process please join in.
M again.
Replied by R40MGF on topic New MGF Wiper Motor
Posted 1 year 8 months ago #209496
Try Rimmer brothers, part number DLB102080.
Replied by David Aiketgate on topic New MGF Wiper Motor
Posted 1 year 8 months ago #209544
Afterthought:
M again.
David Aiketgate wrote:-
I have been through the entire painful freelander motor drama and it is, in practical terms, virtually impossible to isolate the motor from the car earth. You would also need to isolate the wiper mechanism too. As well as fiddle the wiring plug to correct tbe wiring.
I say painful because I test connected the wiring with the motor in my hand, forgetting the motor would self park when live. I ended up with my finger mashed between the arm and the motor body.  Bl****** he**! Ouch!🤬
Also there's a nice electrical short trap⚡️⚡️⚡️ for yourself or any mechanic working on the car...⚡️
Last Edit:1 year 8 months ago by David Aiketgate
Last edit: 1 year 8 months ago by David Aiketgate.
Posted 1 year 8 months ago #209545
Oh yes, when I said floating ground that is exactly what I ment. Any route (or root, that’s for an early morning Cobber, he’ll understand), would have to float or fuses WILL splatter & no amount of upping the value will overcome that!
Time to create page: 1.187 seconds
