Emissions Issues- Help 2 weeks 1 day ago #206587
HI, I need your help.
My 2004 TF has failed its MOT on emissions and I don't know how to get it to pass. I've tried a few things, and I'm rapidly getting to the point its just not worth spending more money on.
The emissions readings gave the following:
CO: 0.000%
HC: 1.4 ppm
Lambda: 1.345
I first tried an Italian tuneup and drive it hard for 30 mins and dropped it off straight into the MOT bay for retest. However, no luck.
The failure is on the Lambda. A scan with Pscan showed an electrical issue with the post cat oxygen sensor. This was replaced by a garage and the code is now gone, but the lambda hasn't come down.
The garage can't find "any obvious issues", and only recommend "sending the car to an ECU specialist".
Any thoughts?
Last edit: Post by andycb.
Emissions Issues- Help 2 weeks 1 day ago #206588
From your errors and emmision test result I am seeing that you have problems with pre-cat lambda sensor. I would change pre-cat lambda sensor for new one and retest. From what you described pre-cat lambda sensor was not chaged.
Emissions Issues- Help 2 weeks 1 day ago #206589
Correct. Only the post cat, as that was the only one returning an error. On my way to pick it up now and find out the damage to my wallet, apparently they had a right time trying to get the old one out. I’m getting pretty worried that this is costing more and more.
Emissions Issues- Help 2 weeks 1 day ago #206590
Not sure if you know but the pre and post cat lambdas are the same part so if they have just replaced the post cat lambda and it didnt make any difference you can reuse the one they took out in place of the pre cat lambda
Emissions Issues- Help 2 weeks 1 day ago #206591
That’s good to know. According to the garage there has been some amateur electrician work going on with the old one. So. It sure how much of a good idea reusing that one is. Maybe a used one from mgfntfbitz is the best way to go…
Emissions Issues- Help 2 weeks 1 day ago #206592
Darren at 'Bitz would be a great source. I ended up with a spare (tested) lambda when I bought a front pipe from him a while ago so let me know if you draw a blank and you can always borrow mine until Darren gets another one in.
Emissions Issues- Help 2 weeks 1 day ago #206593
The “amateur electrical work”, a pound to a penny will be the grafting on of the old connector on to a general purpose sensor.
I did some work quite recently where I amassed sensors from several types & makes of car, the characteristics are so close as to make you ask why such a price disparity.
I didn’t assess the dynamic characteristics of each by screwing them into the car, in turn & run it. Those tested gave similar results.
At the end of the day you’re looking for an MOT pass, the test is academic.
Emissions Issues- Help 2 weeks 1 day ago #206594
That sounds very likely. I didn’t personally see it, but from the description of what they removed it sounds like the error code could have just been the bad wiring job more than the sensor. It has a new Bosch one now though.
Is there anything I can look at in the live data from PScan to establish the health of the not-yet-replaced pre-cat sensor?
Emissions Issues- Help 2 weeks 1 day ago #206595
Considering Bosch we’re the “patentees” of this type of sensor you can be sure it will be within tolerance. Unless it’s a Bocsh, who are a Chinese maker of poor quality rip-off stuff. That’s an untruth but could easily be correct.
Change the other sensor & run the system stinking hot a couple of times & you’ll be in with a very good chance.
Unless the cat’ has croaked.
Time to create page: 0.118 seconds
