No I've had no problems and I've a couple of bolts gone walkies, all depends on the M.O.T tester, I'd say advisory at the most really as long as it's not swinging on a couple of nuts only then everything should be just fineis it an MOT failure if you have two bolts missing from the floor pan?, as two of the nuts under the floor came away from the inner floor, don't know if I should just have it welded for now, or should I try and see if it passes the MOT, really need Help on this one any advise gladly taken,
