COMPONENT | DESCRIPTION | QTY | RS STOCK NO. | COMMENTS | |||
IC1, IC2 | 555 CMOS TIMER | 2 | 221-5535 | DO NOT USE TTL TIMERS | |||
R1,R2,R3,R4 | 47K RESISTOR, 0.6W | 4 | 148-893 | METAL FILM | |||
R5 | 560R RESISTOR, 0.6W | 1 | 148-449 | METAL FILM | |||
R6,R7 | 10M RESISTOR, 0.33W | 2 | 135-997 | CARBON FILM | |||
R8 | 1K5 RESISTOR, 0.6W | 1 | 148-540 | METAL FILM | |||
R9,R13 | 390R, 0.6W | 2 | 148-405 | (390R) METAL FILM | |||
R10,R11 | 10K RESISTOR, 0.6W | 2 | 148-736 | METAL FILM | |||
R12 | 100K RESISTOR, 0.6W | 1 | 148-972 | see text---METAL FILM | |||
D1,D2,D5 | 1N4148 DIODE | 3 | 544-3480 | SIGNAL DIODE | |||
D3,D4 | SCHOTTKY DIODE | 2 | 192-483 | 25V,25A, TO220 CASE | |||
D6 | 1N4001 DIODE | 1 | 628-8931 | 50V, 1A | |||
Q1,Q3 | IRF1104 MOSFET | 2 | 541-1994 | 40V,100A, N-CHANNEL | |||
Q2 | PNP TRANSISTOR | 1 | 671-1107 | BC327 | |||
LED | 3MM LED | 1 | 247-1606 | GREEN | |||
CI | 2200uF CAPACITOR | 1 | 628-3885 | 50V ELECTROLYTIC | |||
C2,C4 | 330pf CAPACITOR | 2 | 537-3561 | 100V, CERAMIC | |||
C3,C5,C6 | 100nf CAPACITOR | 3 | 538-1635 | 50V,CERAMIC, 0.1uF | |||
C7 | 100uF CAPACITOR | 1 | 526-1597 | 50V, ELECTROLYTIC | |||
C8 | 10nf CAPACITOR | 1 | 538-1196 | See text—50V,CERAMIC,0.01uF | |||
INDUCTOR | 47uH | 1 | 191-1131 | 800ma | |||
STRIPBOARD | SRPB VEROBOARD | 1 | 433-826 | 12 strip x 21 holes – to fit case | |||
60mm CASE | 60 x 35 x 20 | 1 | 513-5369 | ALTERNATIVE 381-5091 | |||
IC SOCKET | 8 PIN DIL SOCKET | 2 | 813-115 | CUT OFF PIN 5 ON EACH | |||
TERMINALS | FASTON | 6 | 683-1478 | ¼ INCH FEMALE | |||
INSULATION KIT | TO220 MOUNT KIT | 3 | 712-8225 | Q1,D3,D4 | |||
NYLON SPACER | BOX TO HEATSINK | 2 | 178-692 | M3 x 6mm | |||
6.3mm PC BLADE | CONNECTOR | 3 | 534-834 | DRILL 3mm & MODIFY | |||
M3 SOLDER TAG | 5 | 186-7860 | EARTHS & +VE 12 VOLT | ||||
SCREW | M3 x 20mm | 8 | 560-625 | cut to length where necessary | |||
NUT | M3 | 12 | 560-293 | ALTERNATIVE -6BA | |||
PLAIN WASHER | M3 | 4 | 560-237 | ALTERNATIVE -6BA | |||
LOCK WASHER | M3 | 3 | 276-847 | ALTERNATIVE -6BA | |||
SCREW | M2 x 6mm | 2 | 560-530 | TO MOUNT CKT BOARD | |||
SKOTCHLOK | CONNECTOR | 1 | TO TAP INTO 12V | ||||
ALLOY HEATSINK | 40mm x 40mm CORNER | 1 | 70mm LONG | ||||
CONNECTOR | 1/4” MALE CRIMP | 1 | AIRCON TERMINAL | ||||
HEATSHRINK | 6.4mm BORE | 1 | 341-5944 | 100mm length | |||
HEATSHRINK | 2mm BORE | 1 | 100mm length | ||||
SERVO LEAD | (FUTABA) 3 WIRE | 1 | MODEL SHOP | 125mm length | |||
SILICON TUBING | MODEL AIRCRAFT | 1 | MODEL SHOP | fuel tube as grommet & sleeve | |||
WIRING – BLACK | AIRCON LEAD | 1 | 24 x .2mm – 100mm length | ||||
WIRING – RED | +12 VOLT POWER LEAD | 1 | 24 x .2mm – 330mm length | ||||
THIN WIRING | SWITCH WIRING | 5 | 16 x .2mm – 5 x 200mm lengths | ||||
15mm PIPE CLIP | P clip TO MOUNT C1 | 1 | PLUMBER | drill out to take 3mm screw | |||
LOCTITE | LOCK-N-SEAL | 1 | use to seal alloy mounting nuts |
