Coolant temp gauge 7 years 9 months ago #170516
Just a quickie guys n gals, friends coolant temp gauge has stopped working completely, is there a fuse for it , as i cant see any mention in owners handbook.cheers
Coolant temp gauge 7 years 9 months ago #170517
Only the general instrument fuse. :shrug:
Coolant temp gauge 7 years 9 months ago #170518
Find the blue coolant temp sensor on the engine (you'll need to remove the engine cover).
Check it has voltage in.
I can't remember if it has two wires on the plug but if it does bridge the two and the gauge should go all the way to the top.
If it is only one wire connect this to a light bulb and earth the bulb, it should light and the gauge should move.
If the gauge moves the sensor has failed, if it doesn't the wiring is broken somewhere.
Coolant temp gauge 7 years 9 months ago #170521
See my post BLUE TEMP. SENSOR.
Time to create page: 0.100 seconds
