Hard top hoist 8 years 9 months ago #160686
G'day fellas.
Does any one use a pulley system to lift their hard top off the car?
As I live by myself, removing and replacing/storing the lid can be awkward at times, so I was thinking about using a pulley system that lifts the roof and stores it above the car, much the same as my kayak storage pulley.
Drive under, raise roof and store, lower roof, attach, drive off.
Any pros and cons (CofG, pressure on mouldings etc) are appreciated.
Best wishes all.
Ken
Re:Hard top hoist 8 years 9 months ago #160687
Like this maybe? BMW Z3
Hard top hoist 8 years 9 months ago #160690
No but I did learn a neat trick when it comes to fitting/removing the hard top on your own
Unclip the two back catches.. lift roof a little (front clips still secure) and slide the soft top tonneau cover under the hard top.. then carry on and remove the hard top..
This will stop the hard top damaging the paint on the car
The following user(s) said Thank You: Adyw
Hard top hoist 8 years 9 months ago #160691
What does a hard top weigh?
Hard top hoist 8 years 9 months ago #160692
  • Bertl's Avatar
  • Bertl
  • in the middle of the midlife crisis
it's approx 18kg
as ever,
Rob
Hard top hoist 8 years 9 months ago #160693
  • Bertl's Avatar
  • Bertl
There's a company in the US manufacturing lifts for several cars - not F/TF but should not be too hard to adapt the cradle to match the MG dimensions.
click here to visit hoistlifts.com
....or do it the Merc way: :lol:
as ever,
Rob
Last edit: Post by Bertl.
Re:Hard top hoist 8 years 9 months ago #160694
Thanks fellas.
I was going to purchase an MX5 hoist from Moss but the info provided was fairly sparse re fitting an MG ( they advertise fitting on Google).
I ended up buying a top quality Harken Hoist set up, good for 45KG, and 4:1 pull. I have one for my kayak and they are marine quality stainless and brilliant fittings and cable.
This is important in the humid tropics. I'll post photos of the fitted set up once it arrives in the next few weeks and this will allow me to decide to drop the top more often.
Best wishes all.
Ken
The following user(s) said Thank You: David Aiketgate, Leigh Ping, Andy Lawrence
Hard top hoist 8 years 9 months ago #160716
Being twice my height helps. :P
I've taken mine off a couple of times (when I was replacing the soft top in the snow over a couple of weekends one Febuary) and managed to scrape the boot and the centre console, it hasn't been on since.
I think Richy stores his in the roof of his car port.
Hard top hoist 8 years 9 months ago #160717
I think if I was installing a winch on the ceiling I'd get one that will lift at least 150kg so I could use it to lift engines etc.
Hard top hoist 8 years 9 months ago #160719
The exact wieght for a mgf/tf hard top assuming it is standard mg rover is 20kg../45ibs.................this information taken from mgf/mgtf engine manual. :wave:....seen a few suitable hoists like this one on ebay....
250kg Electric Hoist
Completed
.......as long as you have something suitable to lash it to. :wave:
found this among many bike hoists alot cheaper than the electric one...but needs no power.....this one lifts up to 20kg.
BICYCLE LIFT STORAGE RACK HOLDER PULLEY HOIST BIKE LIFT CYCLE BASEMENT GARAGE
Completed
There is a lot of hoists to choose from.....oh no....another garage project in the pipeline.
MX5 MK 1, 2 & 2.5 HARDTOP HOIST MM900-990
Completed
:beer:
Last edit: Post by mgtfbluestreak.
Re:Hard top hoist 8 years 9 months ago #160722
  • 's Avatar
  • Visitor
  • Visitor
A lot of folk say that the hardtop is easy to move alone. But I've always found it a pig to maneuver on my own and not easy to attach either. However with two people it's easy. :)
Sent from my GT-I8190N using Tapatalk
Re:Hard top hoist 8 years 9 months ago #160723
Invalid or non-existent item ID.sometimes i want the hardtop off ,but dare not risk scratching the paint......20kg is not hard to manage......its because of the size and where you actually grab hold of....has anyone used these before or are they a bit risky...
HEAVY DUTY DUAL DOUBLE SUCTION CUP PAD GLASS LIFTING METAL DOOR LIFTER
Completed
saw a guy on the news who had strapped himself to a chair tied to a number of helium balloons and flew up in the sky before parachuting down.....maybe this is the answer .....let a few of these off inside your mg..........
not quite sure if you will be talking like donald duck if all goes wrong :broon: :vulture:
Time to create page: 4.507 seconds
Powered by Kunena Forum
