Just picked this up for a song 9 years 4 months ago #154357
This sounds very familiar and may be the same issue as discussed In this thread
Haven't read to the end of that thread so can't tell you the final outcome.
Just picked this up for a song 9 years 4 months ago #154358
I have pointed the seller to that post thanks! Fingers crossed. I know I got it cheaper than normal but it should still be fit for purpose.
Just picked this up for a song 9 years 4 months ago #154359
UPDATE:
Seller called me... very helpful chap. Seems they have sold 12 in the last 30 days, and I suspect they haven't yet been fitted!
I've got two options... a. See if a local garage can move the point for me, and they'll sort out a refund to cover the cost, or b. They'll take it back for a refund.
I am going to ask a local garage how much they'd charge to move it the 20mm it needs to go and then speak to the seller again and decide. What a palava! However at least the seller is genuine which is a relief.
Until a solution is found the seller has also taken them out of stock which is a good move.
Last edit: Post by adamelphick.
Just picked this up for a song 9 years 4 months ago #154360
I doubt you'll do much good a a local garage, most aren't up to welding aluminium, better to go to a welding fabication shop.
Just picked this up for a song 9 years 4 months ago #154361
Yes, mine was the same, but I got it to fit by removing the nearside mounting plate,, the rubber collar just fits in the hole left there, not pretty, but it's a worker.
Re:Just picked this up for a song 9 years 4 months ago #154367
I'm tempted on a botch of some kind due to the incredibly cheap price i got it for. I'm sure i could get the slam panel altered to fit easier than alloy welding.
Just picked this up for a song 9 years 4 months ago #154373
That'd be my way of thinking too, lot easier to mod a slam panel than the rad.
WHALE OIL BEEF HOOKED
Last edit: Post by adamelphick. Reason: edited by mistake instead of quote!
Just picked this up for a song 9 years 4 months ago #154385
This is how mine turned out.
Just picked this up for a song 9 years 4 months ago #154387
Agreed - I think I've got a spare from Fleur round the side of the house somewhere.... done carefully the 2cm offset probably wont even notice - and I am loathed to send the rad back as I'll never get another one as cheap as that with the huge cooling capacity it has!
Just picked this up for a song 9 years 4 months ago #154388
Doesn't look too bad... I am thinking of altering the mount to fit so it looks more 'OEM'
Just picked this up for a song 9 years 4 months ago #154392
Looking at that it would be a piece of p!ss (Oz for easy) to just move the mounting plate across the suit the radiator, if you can do that, it's deffo not worth the trouble of trying to move the mounting spigot on the radiator. :broon:
Just picked this up for a song 9 years 4 months ago #154411
Yes, Cobber I thought about that, but you would have to fill in the visible hole on the nearside.
Perhaps an offset plate would do it, but I decided to live with it...how often do you open the front bonnet anyway ?
Time to create page: 0.137 seconds
