Anti-freeze 9 years 5 months ago #153654
Hi
How can I tell which type of anti-freeze is in my 2000 year MGF, it is fitted with a black collar around the expansion tank neck which suggests it is not the oat type, but this could have been changed.
If the cooling system is flushed, is the oat type suitable even if it was not in originally ?
Thanks for any help
Tony
Anti-freeze 9 years 5 months ago #153655
Hi, OAT tends to be orange/pink, but that's not 100%.
As long as you flush it well with clean water you can put OAT in a car that used to have older type fluid. It's far better to go OAT in an alloy engine.
The following user(s) said Thank You: west470
Anti-freeze 9 years 5 months ago #153657
I'd flush and fill with OAT.
Last edit: Post by talkingcars.
Anti-freeze 9 years 5 months ago #153663
Evans waterless coolant is a lot more expensive and needs the system completely flushed with their cleaner first cost is around £130
Time to create page: 0.097 seconds
