  • 2
What to do about hiding the heat shield? 9 years 6 months ago #152174
You can also trim the rear edge of the heat shield to show a Stainless exhaust. :yesnod:
What to do about hiding the heat shield? 9 years 6 months ago #152175
I have an old stainless steel kitchen bin awaiting the angle grinder to reshape it, I also have some MG ZS mk1 bumper mesh to fill the recesses, better than that expanded ali mesh IMHO, already got it in the side grills.
What to do about hiding the heat shield? 9 years 6 months ago #152183
Thanks for the responses. Interesting that no one so far has fitted the Satur S/S cover....but then it's quite expensive. I think I'll try some matt black paint for starters.... any ideas on what type of paint will stick?
Richard
What to do about hiding the heat shield? 9 years 6 months ago #152184
  • bensewell's Avatar
That diamond mesh from Halfords is identical to the proper MG mesh that is used on earlier MGs. I used that and dremmelled the end off the heat shield to show a nice xpower exhaust. Vrooom vrooom.
What to do about hiding the heat shield? 9 years 6 months ago #152197
I ditched the heat shield.. and have gone for 3mm aluminum instead..
Some might call it extreme lol.. But I wanted to hide everything except for the tail pipes
Back end is then aluminum mesh.. etch primed and painted black.
Im happy with how it looks.. ;)
What to do about hiding the heat shield? 9 years 6 months ago #152206
I disagree, proper MG mesh is woven
The above are decades apart........
What to do about hiding the heat shield? 9 years 6 months ago #152208
Heat Shield ???............................................ what heat shield???
Alas mine fell to bits when I changed the exhaust on "Blue 33". Once I get the floor of the bootrepaired amd going to try some adhesive heat shield and reflector. Any suggestions as to if this is a good idea or not are welcome B) .
What to do about hiding the heat shield? 9 years 6 months ago #152213
Talking cars it is the same as the mesh used on my mg, zr, zs, zt & ztt.
It is woven
Not the same as the ancient MGs though
What to do about hiding the heat shield? 9 years 6 months ago #152217
It is woven
Ben
Diamond mesh
mk1 zed mesh
granted mk2 zed mesh is cheaper but I was talking mk1.
What to do about hiding the heat shield? 9 years 6 months ago #152224
I have definitely seen that 'woven' stainless mesh(as the last photo) for sale in Halfords. I agree it's so much better than the perforated aluminium stuff. My F has the woven stainless! :yesnod: :broon:
What to do about hiding the heat shield? 9 years 6 months ago #152242
Mike Satur kindly emailed me the fitting instructions for his cover (£32 + VAT + delivery)
File Attachment:
File Name: ExhaustHea...Trim.pdf
File Size:1,923 KB
He avoids the mesh issue by using perforations.
R
What to do about hiding the heat shield? 9 years 6 months ago #152243
After weighing-up the options I've gone for a matt black finish for now (it can always be covered later on).
Here is a before shot (taken with flash):
I used black waxoyl which dries matt once the solvent has evapourated. I know it's heat tolerant as I daubed a bit on the bionic Panda's back box by mistake months a go and it is still there...it goes a bit soft but sticks. Here the waxoyl is still wet:
And here is the heatshield more or less dry and with some sunlight helping the flash:
I'll let you know how it lasts but the heatshield is much less obvious now.
Richard
  • 2
Time to create page: 0.145 seconds
