Front arch liner crap trap 9 years 7 months ago #149107
  • John and Sue's Avatar Topic Author
This may have been mentioned before, but......
A few days off left me with the opportunity to sort something I've been meaning to do a while: the stone chips/surface rust at the base of the front arches. Apologies for no pics! Never think.
I also completed wiring up the last of my 428 LEDs. Which may have a lie factor of 428.
Standard stuff: wheels off, wire brush in drillo, Kurust, mask up, primer, overpaintable stone chip, spray with rattle can in body colour. Halfords: excellent match btw. Final clear coat. Done. Pleased. Now.... Rewind.
I eased the arch liner away at the back to save masking. Remove self tapper and ease away from the arch flange. It was then that I was amazed by the amount of damp road crud that was trapped and packed behind the lower flange and spread up behind the liner.
I cleared it out with me airline, dosed the gap with anti-rust cack then, an old Skool measure: packed the space with grease. Inelegant but effective. Others may disagree. Waxoyl may be an alternative for those not born in the fifties.
Looking at how the liner fits, it's a perfectly designed crap trap. Something perfectly designed by MGR..... Woo.
Check yours out: remove the rear self tapper and ease the liner away and check behind.
I took the opportunity to replace the front and rear self tappers with new: even sprayed the front two on each side body colour. OCD anyone?
Front arch liner crap trap 9 years 7 months ago #149118
Good work.
And great to see you posting again John :)
Front arch liner crap trap 9 years 7 months ago #149126
A definite crap trap area!:yesnod: You should fit a grease nipple so you can top up the grease! :P
Front arch liner crap trap 9 years 7 months ago #149139
Been there done that
Front arch liner crap trap 9 years 7 months ago #149140
The former owner of my car lived on a farm or at least drove up a farm track.I took a 10 kilo bucket of soil from underneath the arches,a couple of which was behind the arch liners.
I used Stainless screws and washers,not quite as OCD as you John :P
Front arch liner crap trap 9 years 7 months ago #149153
Excellent photo! For the uninitiated, remove that screw and gently ease the liner upwards and inwards to expose the delights beneath. Prepare to be amazed.... :yesnod:
Re:Re: Front arch liner crap trap 9 years 7 months ago #149161
I found exactly the same when I did mine in winter 2011. Followed the same procedure as you john, but 3 years on and the paint has suffered stone chips and the dreaded tin worm is back.
I was thinking about mud guards but I think that will spoil the lines of the car and will probably become a moisture trap. Anyone got any ideas on how to protect this area better?
Sent from my GT-I9100 using Tapatalk 2
Front arch liner crap trap 9 years 7 months ago #149164
I'm hoping that the stonechip coating beneath the paint I applied should bear the worst. If it gets damaged I'll scrape off and redo.
I was tempted by the arch spats but decided against in the end.
Front arch liner crap trap 9 years 7 months ago #149516
Did mine today. Had been meaning to get around to it but thanks to the naggers (and I mean that kindly) I got motivated this afternoon. Yes, I also found a pile of crap which was removed and after everything was properly dry, I applied a lot of black waxoyl (and I was born before 'young John lad') before replacing the lining. I have the MG mud flaps fitted and they don't make any difference to the accumulation of crap behind the liners but they do protect the externals cills - I don't have a problem with how they look.. But then again I like cloth seats.
Richard
Time to create page: 0.109 seconds
