Ahh ive found where it is. Slightly different place.
It it right that it makes no difference if it is plugged in or not?
May not be related but you could also try a reset of the throttle position sensor;
Switch the ignition on but don't start the engine.
Press the throttle down fully and release 5 times
Wait 10-15 seconds and switch off the ignition.
Next time you switch on the ECU will have been reset to the max-min values of the TPS.
