Kickstart project for a Diagnostic tool 9 years 6 months ago #152116
It should do as Adam has 2no. O2 sensors so it's Mems3. looking at my o2 sensors on Torque gives me wowing on both (as Adam describes it)
Kickstart project for a Diagnostic tool 9 years 6 months ago #152127
Hi Philip - yes it does log on with EOBD - I'll do it in the morning and post results.
Kickstart project for a Diagnostic tool 9 years 6 months ago #152684
OK so I haven't done much this week as I have had yet another cough and my mum went in to hospital (all ok now)... so yesterday I swapped my modified 48mm allot throttle body for a bog standard 48mm alloy one... and the hunting I've been getting is a LOT better.. slight wowing on and off. The engine still runs what I consider to be lumpy though on tickover despite me raising it to about 800 RPM.
I checked the error codes again and now have:
P0481 Cooling Fan 2 Control Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
The second cooling fan is fine as I don't have air-con, however the Solenoid one is new! I've erased them and will see what comes back. With the engine idling (slight wow up and down between 800 and 900 as far as i can tell)
The live data is now as follows:
So anyone know what's going on maybe? I changed the engine bay air temp sender and it still reads 139 degrees!
I am just about to free up Meg's alternator which is seized, bung some petrol in her and fire her up too... so I'll report back what I find there later!
Last edit: Post by adamelphick.
Kickstart project for a Diagnostic tool 9 years 6 months ago #152686
OK some more info. He's been sat a good 15 minutes idling.. and all of a sudden hes hunting up and down from 850 or so to 1200 maybe... nothing done apart from idling.
Also here are the EOBD readings:
Kickstart project for a Diagnostic tool 9 years 6 months ago #152697
If it's hunting up to 1200 then the base idle is slightly too high. How far did you turn the idle screw? Turn it back half that amount.
Getting the base idle correct is not easy because the iacv and ecu are always trying to get it to 850-875. The IACV has to be on the 'correct step' for it to work. i.e you set the idle to 850, the car idles OK for a while then the ecu/iacv moves a step and the idle is wrong again.
It really is a case of little changes and leave it to sort itself out. If it's hunting down below 800 turn the screw in slightly, if it's hunting up, turn the screw out slightly. No more than a half a turn.
Kickstart project for a Diagnostic tool 9 years 6 months ago #152714
Cool - will give it a go David. It's certainly a million times better withe the standard throttle body.
I found the injector rail it originally had I think in the shed - with blue injectors - you think it's worth bunging that back on too as I can't remember what one I put on when I changed to the alloy inlet manifold!
Typically when I got Meg started she had no faults, and everything seemed just right on e
the scanner! That's after being stood for a year with maybe a few half hour tick-overs!
Kickstart project for a Diagnostic tool 9 years 6 months ago #152795
Nudged it down a tad on tickover and it is slightly better - will try again with another 1/4 turn tomorrow maybe. What 'step' should the IACV be on? Seems to be showing 0 step on mine on tickover.
What so we think about swapping the injectors over? Does it matter what colour the ones on it are? The ones I have in the shed are blue.
Also as can be seen in the reading above the engine bay temperature sender is still reading 139 degrees ads it the fuel temperature. As I said I swapped the air temp sender over from the F, and it works as it should when I pull it off - the fan comes on. So far haven't seen the fan actually come on of it's own accord though!
Kickstart project for a Diagnostic tool 9 years 6 months ago #152796
I can't remember which way it works but the different colour injectors have different flow rates with 160VVC on MEMS3 flow less than the 143VVC on MEMS2.
Kickstart project for a Diagnostic tool 9 years 5 months ago #153189
So finally got round to lowering the tickover a tad again. It is now between 850 and 875. I have no idea though what the readings for the stepper etc should be as although the pscan unit is brilliant (and so well supported by the maker), we don't have a 'reference point' for each vehicle so we can check if things are right.
Here are the results of today's readings once Felix was warmed up -
MEMS 3 Rover connection:
MEMS 3 BMW connection:
EOBD connection:
Error codes (cleared and come back):
Although he now runs without hunting (so far - a drive will tell for sure!), there is still a lumpiness about his tickover. For example I start Meg after months of her sitting on my drive and she is smooth as butter! There's like a hesitation that is apparent on the tickover with Felix, it's not really bad but it does make his engine shake and the exhaust rattle a bit.
So any help greatly appreciated as always.
Kickstart project for a Diagnostic tool 9 years 5 months ago #153190
I think it's a great tool as well Adam but would also like a reference table to know what the readings really mean. I've searched the net but can't find anything.
If anyone comes across something, hopefully they'll post it somewhere and we can all pick it up. Needed for all mems versions of course.
Kickstart project for a Diagnostic tool 9 years 5 months ago #153191
I presume if we could get our hands on a T4 manual then maybe that would reference what is expected on the readings?
Kickstart project for a Diagnostic tool 9 years 5 months ago #153192
Hmm.. doesn't help - found it!
Time to create page: 0.243 seconds
