  • 2
Key Fob Range 9 years 11 months ago #142441
Despite a good battery, the remote unlocking on my MGF has a very limited range. Do you think this will help?
Richard
The following user(s) said Thank You: Badger
Re:Key Fob Range 9 years 11 months ago #142443
You need to take the passenger footwell cover off, find the skinny yellow wire, unwind it and tape it extended under the dash. That helps a bit!
Sent from my GT-N7105 using Tapatalk
The following user(s) said Thank You: Bob, Blow-in
Key Fob Range 9 years 11 months ago #142448
I found the new battery helped but ten feet is about the limit.Yes holding it against your head does work Richard :yesnod:
Thanks for the tip Adam :broon: A little job for the future.
Last edit: Post by Bob.
Key Fob Range 9 years 11 months ago #142449
Goodness knows why they put a decent aerial on it then wound it up!
Holding under your chin is apparently the favored way to extend the range.
Key Fob Range 9 years 11 months ago #142450
Mine seems to work OK from @ 25 - 30ft.
I dunno if the aerial wire has been unwound though.
Key Fob Range 9 years 11 months ago #142456
Mouth open or closed?
R
Key Fob Range 9 years 11 months ago #142457
Brilliant. Cheers Rich. :broon:
Key Fob Range 9 years 11 months ago #142459
You may have a different frequency of key fob in OZ as different country's assign or allow different bandwidths for radio transmissions, in the uk the MG Rover Pektron fob is 433 mhz. which in my case equates to about 2 mts max.
Not sure about the aerial wire on the Pektron unit; or if it's the same as the Lucas A5 but your 30' range would be nice.
Brian.
Key Fob Range 9 years 11 months ago #142463
Yeah, now that you mention it, we do use a different frequency. 315 MHz :yesnod:
Key Fob Range 9 years 11 months ago #142468
Put new batteries in mine and it is still crap about 3 feet max :bang:
Key Fob Range 9 years 11 months ago #142469
My range is very poor and I would like to try and improve it.
Apparently the aerial is a yellow cable taped to the loom behind the passenger footwell triangular cover and is tuned to a 1/4 wavelength.
Just has a look on a radio HAM site and it says to find the full wave length divide the frequency of the transmitter (433mhz) by the speed of light in meters per second (299,792,458 m/s) and you get the wave length in meters, so it should be:
300/433= 0.6928406467 meters divide by 4 for 1/4 wavelength =0.1732101617 so the cable should be 173mm, I am going to have a look over the weekend and extend it to 1/2 wavelength (346mm) and see if it is improved.
Key Fob Range 9 years 11 months ago #142520
Forehead/mouth closed works well.
They have a restricted range to reduce the change of an unintended unlock event going un-noticed.
  • 2
Time to create page: 0.134 seconds
