I report the development and my curret idea
The “CJJ/Jaylad aftermarket” bracket trasforms the effort, generated during braking by the leverage to servo/brake pump assembly, in a torque bending of the upper sheet of the bulkhead. The bracket is bolted to the 3 holes for the snorkel, there is like a protruding wing, the bulkhead metal sheet is very thin, more it has been weakened by the 2 big rectangular holes for the LHD/RHD air inlet.
Due to weakeness of the upper bulkhead sheet the bracket, even it's properly done and strong, still has some movement, but this is normal being a beam with just one flexible support.
The first solution I studied was to develop a new bracket with large upper flange to copy the snorkel flange, may be 3 mm stainless steel, in order to share the load on a larger surface and not just on the front 3 bolts.
Than I was looking for some kind of shaft strut, suitable to tansfer the load to a stronger chassis member, but I saw that i.e. the battery/barke modulator box is not enough strong, all the metal sheets there are very thin and flexible.
At this point I investigated the deflection of the other side (driver) measuring a bigger deformation (1,25). Then I asked how use the front subframe crossmember, it's strong enough.
The attached picture shows my current proposal, a bracket that shares the load 50% +/- with the upper bulkhead (using 1 or 2 of the 3 holes) and the other 50% with the main subframe (1 or 2 * 6 mm holes have to be drilled in the upper wing of the C cross member frame), I guess that my sketch will clarify the proposal. The bracket will act as a beam with 2 support, without torque effect.
Open to your suggestions and comments, scope to find a simple and effcetive solution easy to be fitted
