  • 2
error codes 10 years 9 months ago #123957
hopefully somebody can put me on right track my tf has been running a little rough for a week so whilst my local garage replaced my rear discs and pads I asked them to check it out and they got following error codes which are all historic
P1232 fuel pump relay test not complete
P0650 malfunction indicator lamp (mil) control circuit malfunction
P0481 a/c condenser fan ( my car hasn't got ac )
P1191 rear lambda sensor per-heating test not complete
P0445 purge valve drive test not complete
P1539 air conditioner evap temperature sensor , short circuit to battery
P1316 misfire causing excess emissions test not complete
I've had ecu remap by z & f tuning about 18 months ago and as my local garage don't have much to do with tuning they said it might be something to do with problem but after 18 months seems to be odd to me,
can any body point me in right direction to sorting problem out...?
Thanks
Rob
error codes 10 years 9 months ago #123958
did they reset the faults and see whats left ??
mine comes up with the air con fault ,impossible to clear and again i dont have air con
error codes 10 years 9 months ago #123960
hi paul not sure sure I've just got print out with error codes
error codes 10 years 9 months ago #123961
Well they could be all historic as they dont clear themselves so unless theres something wrong with the way the cars running i would not let it bother you to be honest
The following user(s) said Thank You: verve34
error codes 10 years 9 months ago #123966
Presuming mems3 as you have had the car remapped, I would get yourself a cheap obd2 reader off ebay.
Clear all the codes and then see what comes back up after a run.
Most of those faults could have happened ages ago and are just stored in the ecu.
If the initial reading showed no current faults this is very likely.The last code is the one most likely to cause slight running faults.
OBD2 readers come pretty cheap and are not hard to use. You can get various kinds standalone;plug into laptop; and the kind I use a little bluetooth unit that plugs in and you get a readout on your smartphone using an app called torque.
They allow you to see and clear fault codes; clear the MIL light, and the 2nd two allow you to see live sensor data.
error codes 10 years 9 months ago #123969
Is mems3 the ecu if so not sure if mine is I just got z & f to remap it for me the error codes are all historic so the garage put on the printout
error codes 10 years 9 months ago #123970
Just had a look on flea bay for a obd2 reader there are lots off different kinds will they all allow me to reset all the codes ..? and are some easier to use than others..?
error codes 10 years 9 months ago #123972
Invalid or non-existent item ID.Invalid or non-existent item ID.If you have a smart phone go for a bluetooth one. I'll find a link for you. Hang on.
I got one like this.
error codes 10 years 9 months ago #123974
thanks david just purchased one
error codes 10 years 9 months ago #123975
Now look for and download the Android app 'torque'. There is a free version or a paid version with a bit more extras available. The free version is fine for fault codes etc.
error codes 10 years 9 months ago #123981
David I don't have an android phone I have a iOS device
error codes 10 years 9 months ago #123982
for ios device without jailbreak you will need the wifi version, the bluetooth version does not work.
(thank you apple)
Last edit: Post by peter81.
  • 2
Time to create page: 0.976 seconds
