HELP!!! - Car wont start 10 years 10 months ago #122162
Almost fired and stink of petrol sounds like flooded. Pull the inertia switch out to prevent further flooding. Crank the engine. If flooding was the problem it will eventually start up and then peter out from no fuel. Push the inertia switch back in and start normally.
I think I've found the black rubber topped switch thingy in the boot (on the passenger side).
Seems easy enough to push down but how do you pull it out?
The fuel cutoff relay pops up when activated and has an audible click when it's reset (pushed down)
No noise when it's already been reset.
WHALE OIL BEEF HOOKED
The following user(s) said Thank You: richandpaula
HELP!!! - Car wont start 10 years 10 months ago #122163
When you put the window fuse back in did the window work??
Just checked, window is working with both fuses.
HELP!!! - Car wont start 10 years 10 months ago #122164
Nope, just been looking at it, can't see any way to pull it up, and it's deffo in the down position as i couldn't push it down or feel any click when doing so.
HELP!!! - Car wont start 10 years 10 months ago #122165
If its in the down position then there's nowt wrong with it.
It pops up in the event of a collision.
HELP!!! - Car wont start 10 years 10 months ago #122166
What does fuse f23 control??
HELP!!! - Car wont start 10 years 10 months ago #122167
Hope it's ok to post these images here...
HELP!!! - Car wont start 10 years 10 months ago #122168
Now then.
Seems to point to fuel pump.
Check loom to pump and any relays.
HELP!!! - Car wont start 10 years 10 months ago #122237
Had the battery off all day today while Paula took it back to ATS to get it tested.
(Tested fine btw).
So I put the battery back on tonight.
(after another ride home on the pushbike in the rain - found a nice canal path route rather than the main town and traffic now) and the car started first time...and second time...and third time!!!
Just put my coat on to take it for a quick 20 mile run to see if it is ok, (got break down number, phone, water, coke, mars bar, crisps, etc in case it breaks down - not optimistic here) tried to start it again and it won't start.
Fed up
HELP!!! - Car wont start 10 years 10 months ago #122238
  • cjj's Avatar
It sounds like a loose connection on the HT side of things. Could be anything from the ECU up to the coil packs.
Sorry to be so vague, but I think it's going to be one of those sort of faults.
HELP!!! - Car wont start 10 years 10 months ago #122312
Spent the morning getting the roof up, removing the inspection cover and getting the car ready for working on and just got a text from the mobile mechanic i had arranged coming out this afternoon to let me know he can't make it.
Tried to call John Norris, Russel and Dave & Kayleigh - all going to voicemail.
Anyone know of another good mobile mech that covers cheshire?
HELP!!! - Car wont start 10 years 10 months ago #122348
John's phoned me back, Top bloke.
This afternoon I've gone through all the fuses in both the engine bay and the footwell, all ok.
Tried spraying every electrical connector i could find with WD-40.
Unplugged the dual horns I've added.
Pulled the spark plugs out and turned it over. Checking they were sparking by holding the end of the plug against the top of the engine - small blue spark seemed fine. Even replaced them but still no joy.
I'm at a loss now.
Edit: Where's the starter motor and what does it look like?
(last time i had to deal with something like this was over 20 years ago on a Mk1 golf!)
Last edit: Post by richandpaula.
HELP!!! - Car wont start 10 years 10 months ago #122349
Did you take battery off and put back on Richard, just someone said it seemed to be every time you messed with the battery it seemed to start. Also have you taken the earth lead from the battery that attaches to the slam panel off and cleaned it.
Not sure were the starter motor is but take a look here.
http://www.mgfcar.de/starter/start.htm
Time to create page: 0.184 seconds
