Coolant hose split- an autopsy and SHOCK DISCOVERY 11 years 2 months ago #104904
Take heed dear listener, for I have a tale to tell.
Being of an inquisitive mind (nosy git) I decided to investigate why the hose had decided to fail so spectacularly.
This is the hose in question.
So having removed the hose I decided to perform an autopsy.
It seemed clear that the hose had blown out rather than being cut or damaged externally.
The first incisions.
Coolant hose split- an autopsy 11 years 2 months ago #104906
What the hell is this?
Coolant hose split- an autopsy 11 years 2 months ago #104907
Coolant hose split- an autopsy 11 years 2 months ago #104908
This is where this restriction was.
Coolant hose split- an autopsy 11 years 2 months ago #104909
Any ideas where this has come from? :-?
Coolant hose split- an autopsy 11 years 2 months ago #104910
This shows how restricted the flow would have been.
Coolant hose split- an autopsy 11 years 2 months ago #104911
Hmmm, interesting find. Can I assume this was under the jubilee clip where the two pipes meet? Is it there to have something solid to clamp one pipe over the other to or specifically to restrict the flow?
I look forward to hearing a proper answer.
Coolant hose split- an autopsy 11 years 2 months ago #104912
No, the pipe on the left(in the photo) of the restriction is metal so the rubber hose clamps to that.
The offending article with the rest of the Jiggle Valve
Coolant hose split- an autopsy 11 years 2 months ago #104913
From here?
Coolant hose split- an autopsy 11 years 2 months ago #104919
  • cjj's Avatar
Just a restrictor I assume, to create a pressure differential maybe.
Last edit: Post by David Aiketgate. Reason: sp
Coolant hose split- an autopsy 11 years 2 months ago #104921
So this begs the question(s)
What is the reason for this?
Does the silicon replacement pipe have the same restrictor and, if not, what are the implications?
As usual from me - all questions and no answers :coat:
Coolant hose split- an autopsy 11 years 2 months ago #104923
  • bensewell's Avatar
Dr David I'm disappointed where are the surgical tools and gloves ? That pipe looks naff another rubbish idea by rover the cost cutting cowboys
Time to create page: 0.119 seconds
