Drivers door lock... retaining clip 11 years 3 months ago #101714
Hi,
new to this forum.. but I have a question I need an answer for..
the clip the holds the lock into the Door handle... how do yuo refit it?
is there a special technique? or a special tool needed?
cheers
Allan
Drivers door lock... retaining clip 11 years 3 months ago #101715
  • cjj's Avatar
Hi. Welcome to the forum.
Do you have any pics as I don't think I've done the clip but I can't be sure.
Drivers door lock... retaining clip 11 years 3 months ago #101716
Persistance unfortunately. It should just slip in though. Make sure the barrel is positioned correctly though
Drivers door lock... retaining clip 11 years 3 months ago #101718
the clip number 9....
its impossible to get my hands anywhere near where it needs to be
Last edit: Post by allanicars.
Drivers door lock... retaining clip 11 years 3 months ago #101720
Insert it upside down, instead of a 'n' make it a 'u'
Drivers door lock... retaining clip 11 years 3 months ago #101722
As John says, insert it from below. It is also easier to fit, if the lever in the diagram is not attached to the door lock until you fit the clip!
... and :welcome2:
Drivers door lock... retaining clip 11 years 3 months ago #101727
won't it have the chance of falling out?
I know when i removed it.. it was definately at the top...
Drivers door lock... retaining clip 11 years 3 months ago #101735
No it will hold fine. I put mine in that way around, and it's still in place after 18 months.
Drivers door lock... retaining clip 11 years 3 weeks ago #114101
Is the clip part number CWH10003. I ask as mine has done the same.
Drivers door lock... retaining clip 11 years 3 weeks ago #114157
Can't you turn it round once fitted using long nose ?
Drivers door lock... retaining clip 11 years 3 weeks ago #114171
mine is in upside down, it was the only way I got it fitted 12 months in situ no issue
Time to create page: 0.107 seconds
